Thread: How much should i pay? |
New member Username: Theceo
Post Number: 2 Registered: Apr-05
| Posted on Saturday, April 23, 2005 - 03:21 pm: |
im new to all this stereo stuff so try not to laugh at me too much, but i went to this shop to see how much they would charge to hook up my 2 kicker subs to my 300w kenwood amp and my cd deck, and he said about 100 i think. but then he said i would probably need a bigger amp to push my kickers. is he right? do i need a bigger amp? and is he ripping me off with that price? thanks in advance. |
Gold Member Username: Taylor17
Kopperl,
Texas
Post Number: 1497 Registered: Jan-05
| Posted on Saturday, April 23, 2005 - 03:24 pm: |
Wich Kickers is you're amp going to, and what is the amps spec's? Is that including wiring. That isn't bad, but you could prob do it yourself, unless you don't trust yourself.:-) |
Post Number: 3 Registered: Apr-05
| Posted on Saturday, April 23, 2005 - 03:32 pm: |
im not sure which kickers they cuz i have them in a box already but i think they had like 4 ohms each, and yea the price included wiring. these are the specs of a newier version of my amp. Key Features Amplifier Type Mono Channel Bass Boost With Bass Boost Bridgable Not Bridgable Power Output RMS Power at 2 Ohms 230 W x 1 RMS Power at 4 Ohms 150 W x 1 Performance Frequency Response 5 Hz - 200 Hz Low - Pass Frequency 50 Hz - 200 Hz Signal to Noise Ratio 100 dB Bass Boost Frequency 90 Hz Dimensions Width 11.44 in. Depth 7.88 in. Height 2.19 in. Other Features Input Voltage 11 volt MOSFET amp Yes 3 Way Ready No Miscellaneous MPN kac-719
Silver Member Username: Goon
Post Number: 119 Registered: Feb-05
| Posted on Saturday, April 23, 2005 - 03:40 pm: |
hmm even without specs i would say you would need more watts for the subs...you could puch it with that, but more than likly it would be underpowering. ok price for installation since it's including the wireing. circuit city will charge like 120 without parts. installing it isn't hard, it's a matter of looking at pictures. goon |
Post Number: 4 Registered: Apr-05
| Posted on Saturday, April 23, 2005 - 03:42 pm: |
is installing it that easy? is there how to website somewhere you could link me to? |
Post Number: 5 Registered: Apr-05
| Posted on Saturday, April 23, 2005 - 03:44 pm: |
is this a good amp to get? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem%26%26item%3D7968561739& category=38638
Kopperl,
Texas
Post Number: 1502 Registered: Jan-05
| Posted on Saturday, April 23, 2005 - 03:54 pm: |
The link didn't work for me. What is the name of the amp? www.bcae1.com is a pretty good website to learn about car audio. Take a look at that and see what you learn! |
Post Number: 6 Registered: Apr-05
| Posted on Saturday, April 23, 2005 - 03:59 pm: |
this link should work http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39734%26item%3D5768909398 %26 |
Post Number: 7 Registered: Apr-05
| Posted on Saturday, April 23, 2005 - 04:19 pm: |
Post Number: 121 Registered: Feb-05
| Posted on Saturday, April 23, 2005 - 04:43 pm: |
you are having bad luck with these links man. tell us brand and model, plus specs. we'll let you know. goon |
Post Number: 8 Registered: Apr-05
| Posted on Saturday, April 23, 2005 - 04:50 pm: |
its a 600w kenwood amp, KAC-728S. here are specs i got off a website. Amplifier Type Dual Channel Bridgable Bridgable Power Output RMS Power at 2 Ohms 150 W x 2 RMS Power at 4 Ohms 100 W x 2 Performance Frequency Response 5 Hz - 50000 Hz Signal to Noise Ratio 100 dB THD at Rated RMS Power 0.08 % Dimensions Width 8.69 in. Depth 11.81 in. Height 2.19 in. Other Features Input Voltage 11 volt MOSFET amp: Yes 3 Way Ready: Yes
