Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2005 > Bad GrounD???please help
Author Thread: Bad GrounD???please help
Username: Vwgn
Post Number: 11
I hooked up my amp today and all and everything points to my shi**y spot for the ground...it turns on for a bit then shuts off..no fuses blown no protect light..could the sub hooked up wrong be the issue? and also if my amp has a fuse rated at 30a and my amp wiring kit has a 60a fuse matter? thanks
Username: Stylnul
Victorville, CA
US
Post Number: 28
if there is no protect light going on, and if it shuts off and on, the most obvious troubleshoots could be a loose rem connection or your ground could loose as well. and as far working goes a 60 amp fuse wont cause your amp to shut on or off.
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2005 > Bad GrounD???please help [ « Previous ] [ Next » ]
