Thread: Keep bass boost on, any loss from this? |
Bronze Member Username: Crusacargen
CA
US
Post Number: 11 Registered: Feb-05
| Posted on Friday, April 22, 2005 - 12:05 pm: |
I was wondering if there would be any bad results if you keep the bass boost on. |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 358 Registered: Oct-04
| Posted on Friday, April 22, 2005 - 01:39 pm: |
Are you referring to the "Loud" or "Bass Boost" on your HU or the Bass Boost knob on your amp? It's ok to put it on, just be very careful if you had your gains set, because it's going to be pumping more to your subs then before. If it's your bass boost on your amp, a little is OK, definately don't max the knob out though. |
NorthWest,
Michigan
Post Number: 7670 Registered: Dec-03
| Posted on Friday, April 22, 2005 - 02:25 pm: |
bass boost circuits can introduce distortion and clipping. that's bad. the key is judicious use of the system, and being careful not to keep the system volume up if you do hear any distortion.
