Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2005 > Enough Battery Power??
Author Thread: Enough Battery Power??
Blair
Q.1 I was looking at buying a Optima Yellow Top, 650 CCA rating. It will be providing power for a MTX 1501D and a MTX 4x85 watt (cant remenber the desc. no) Will this be enough or should I look at some thing bigger?
Q.2 Are the Stinger dry Cells any good?
Username: Glasswolf
NorthWest, Michigan
Post Number: 7676
the yellow top is fine. you can reference the discharge time based on current draw on their website to see how long the battery will last with ~100A of draw.
the battery only helps if the engine is off.
when the car is running you'll want a HO alternator to handle the drain.
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2005 > Enough Battery Power?? [ « Previous ] [ Next » ]
