Thread: Amp wiring |
| Posted on Thursday, April 21, 2005 - 08:59 pm: |
How do you parallel wire a mono 2 channel amp? Can someone make a picture and explain it to me? |
Silver Member Username: Kojak28
Augusta,
GA
Post Number: 136 Registered: Feb-05
| Posted on Thursday, April 21, 2005 - 10:21 pm: |
Parallel and series wiring techniques involve speakers' wiring TO the amp. Are you referring to a 2 ohm stable mono block amp? Give me some specs and some particulars on what you are doing. |
| Posted on Thursday, April 21, 2005 - 11:09 pm: |
I am going to get a mono amp, its 2 channel and stable at 2 and 4 ohms. My subs are 4 ohm single voice coil, and I want to connect them to the amp at 2 ohms. I need someone to make a picture of how I would parallel wire. |
Silver Member Username: Goon
Post Number: 102 Registered: Feb-05
| Posted on Thursday, April 21, 2005 - 11:30 pm: |
I might be wrong, but I dont think you can wire single voice coil 4ohm to 2ohm, i think it would have to be 4ohm dual voice coil. anyone correct me if im wrong. goon |
Bronze Member Username: Velk4425
Post Number: 17 Registered: Feb-05
| Posted on Thursday, April 21, 2005 - 11:37 pm: |
http://www.the12volt.com/caraudio/boxcalcs.asp |
Bronze Member Username: Treeguy2oo4
Phoenix,
Arizona
Post Number: 34 Registered: Feb-05
| Posted on Friday, April 22, 2005 - 01:01 am: |
bro this guy dos not know what he saying! yes you can get them to 2 ohms. look on the net!!!!!! |
Bronze Member Username: Langner
Madison,
South dakota
US
Post Number: 96 Registered: Apr-05
| Posted on Friday, April 22, 2005 - 07:47 pm: |
yes you can if you have 2 subs
| Posted on Friday, April 22, 2005 - 10:00 pm: |
You see, you have to read everything, MONO amps are not 2 channel, they are ALL 1 channel (how come no one said that before) anyways the amp mono amp that I am going to get looks like a 2 channel amp, but actually it parallels in side the amp. Like the pic. http://pic17.picturetrail.com/VOL809/3228131/6595604/93959061.jpg |
