Thread: Help! wiring sony amp and 3 mtx speakers |
New member Username: Cadillactodd
Post Number: 1 Registered: Apr-05
| Posted on Thursday, April 21, 2005 - 04:35 pm: |
I have 3 MTX Thunder 6000,4 ohm(i think)svc speakers,wired in parallel,and i just bought a sony xplod xm-d1000p5,1600 watt amp(used). the amp is a mono-channel amp. Can i run 3 speakers from it? How do i hook it up? There are 2 right positive terminals and 2 left negative terminals(i think). Do i hook the wires on one set of L/R,or + on one side,and - on the other side? The amp has a protect/power light. It lights red and green. Which color light is power,which is protect? I hooked it up at first and the light was green,and i didn't get any sound. I changed the terminals around a little, and the light was red,but i still didn't have any sound. Iam using 4 ga. power cable,and i tried 2 sets of rca cables just in case.Any suggestions? |
