Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2005 > Will this work?
Author Thread: Will this work?
Username: 1stimer
Post Number: 11
ppi a400.2 amp = 50x4 @ 4 ohm.
image dynamics cxs52 5.25" components= 50 watts 2ohm
idq-10 sub = dual 2ohm 250 watts
Will this all work together? Thanks to anyone who will let me know.
Username: Bnd_rulez
Phoenix, AZ
Post Number: 491
Running both the comps and the sub off that one amp? You'll probably need something more powerful for the sub.
Username: 1stimer
Post Number: 12
Thanks David....That's what I was afraid of...I just want to run 1 amp, and was thinking that bridged I would be giving it 200 watts of good power...was just hoping....back to the drawing board.
Username: 1stimer
Post Number: 13
If I guy wit a more powerful amp won't I be overpowering the components?
Username: Bnd_rulez
Phoenix, AZ
Post Number: 504
If you keep your gain turned down you shouldn't encounter any problems. Just keep the gain/level down to almost nothing.
Username: 1stimer
Post Number: 16
Thanks David. mounting depth, my 70 amp alternator, money, and my needs are pushing me in the direction of a smaller system. I just want better than stock..not trying to go crazy at all (obviously), so a 50X4 won't cut it? Won't a 50 X 4 give me 200 watts to the sub? Why is this not enough? The sub is only rated at 250 watts. So you are saying go for a 75x4? Just think if I do that I should change my components. Any thoughts? Thanks
Username: 1stimer
Post Number: 17
http://www.sounddomain.com/sku/PHOR804
do you think this would power everything properly?
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2005 > Will this work? [ « Previous ] [ Next » ]
