Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2005 > Wow i think im screwed
Author Thread: Wow i think im screwed
Jessey
when its all said and done i'll only have about 70-100$ left, and i still need a amp!!! Any possible way i can get a good amp(2ch about 300 rms) should i consider "off brands" or go for a lower wattage name brand
Username: Bnd_rulez
Phoenix, AZ
Post Number: 439
Save the money for a little while and get something decent. No use rushing when you're so close to what you want, excercise patience.
Username: James1115
Wilton, Ct
Post Number: 2393
I fully agree with David no matter how hard it is its the best thing to do, and always watch ebay.
Jessey
so when i have about how much money should i start looking.. because i make like 30 a freakin week!!!
200 $ range?
Username: James1115
Wilton, Ct
Post Number: 2404
what do you need this amp for subs, or mids + highs? and do you need 2x150 or 2x300?
Jessey
well earlier i was told to geta atlas 12" over 2 kicker crv's(good idea because everyone thought it was better) in a bandpass box.
so i need somthin to power that and i heard it dosent take much to get it bumpin--250rms or somthing sounds kinda low but heard good things... you think it was the right choice over the crv's???
Username: Bnd_rulez
Phoenix, AZ
Post Number: 474
Most definitely the correct choice. You will need an amp that pushes 500 watts X1. Good amp on a budget for those subs would be an MTX 6500D.
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2005 > Wow i think im screwed [ « Previous ] [ Next » ]
