Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Setting the clock on Pioneer deh 15
Author Thread: Setting the clock on Pioneer deh 15
Username: Hsuomar
After much frustration and searching, i finally figured out how to change the clock on my Pioneer deh 15. While the radio is on, hold down the source key until the unit turns off. The clock should still appear. Then hold down the audio key until the numbers on the clock begin to flash. After that use the cursor to navigate between hr/min or to inc/dec the time. Hope this helps.
Username: Mader114
http://www.cartoys.com/cartoy/pdfs/deh1500_manual.pdf#search='clock%20setting%20Pioneer%20deh%2015'
Then look under section 7 and it explains it to you
Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Setting the clock on Pioneer deh 15 [ « Previous ] [ Next » ]
