Thread: Wiring 2 channel amp for components? |
New member Username: Coloursinmyhead
Post Number: 4 Registered: Mar-05
| Posted on Wednesday, April 20, 2005 - 04:30 am: |
I'm going to be running a PPI 2300.2 amp which is rated at 150watts/2channels at 2ohms to my Infiniti Kappa 6.1 components, which is rated at 250 watts rms at 4 ohms. Should I run the speakers at 4 ohms, and if so, how do I go about wiring them to do this? The instructions say the amp will power the speakers at 75 watts at 4 ohms, but there's no information on how to wire them to do this. Do I just wire them in parallel? Sorry for another noobish question |
Post Number: 5 Registered: Mar-05
| Posted on Wednesday, April 20, 2005 - 04:36 am: |
oh yeah it's a PPI PC 2300.2 if that matters |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 413 Registered: Mar-05
| Posted on Wednesday, April 20, 2005 - 03:56 pm: |
Run the wire from the amp to the crossover input, than you'll see W+ and W- and T+ and T-. Just run speaker wire from W+ to the Woofers positive and W- to the woofers negative. The tweeter shoild have black and red cables run theblack/red cable to the neg and the all red cable to the pos. You don't need to wire the speakers in parallel or series. Just straight up wire them. |
Phoenix,
AZ
Post Number: 414 Registered: Mar-05
| Posted on Wednesday, April 20, 2005 - 04:00 pm: |
I have those speakers and enjoy them, hope you do to. Also when you mount your tweeter, I suggest mounting it near the woofer and the sound will blend better. |
Post Number: 6 Registered: Mar-05
| Posted on Friday, April 22, 2005 - 12:16 am: |
thx for the reply, David. how can i make sure they're running at 75@4ohms as opposed to 150@2ohms (or does it not matter)? |
Phoenix,
AZ
Post Number: 507 Registered: Mar-05
| Posted on Friday, April 22, 2005 - 02:29 am: |
You'll have to get a volt meter and touch it to the wire. If the amp says they'll only be getting 75 at 4 ohms then thats what they'll be getting. I have mine running at 100 watts, and they're doing fine. |
