Thread: Amp for my 12" Atlas |
Bronze Member Username: Tpizzle
Post Number: 84 Registered: Apr-05
| Posted on Tuesday, April 19, 2005 - 07:23 pm: |
I need help deciding on an amp for my 12" Atlas. i know it doesnt take much power. i have $200 any suggestions? |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 401 Registered: Mar-05
| Posted on Tuesday, April 19, 2005 - 07:27 pm: |
Anything that will put out 250 watts. Look at PPI Art Series and PC/PCX series, they are awesome amps and would be a perfect match for that sub. |
Post Number: 88 Registered: Apr-05
| Posted on Tuesday, April 19, 2005 - 11:33 pm: |
ide love to go with that quality but thier $400 amps. i need something under $200 that will run my 12" Atlas nicely. 250rms not sure about max. any suggestions for amps, how about hifonics, fosgate, or ??? |
Silver Member Username: Fishy
Tamarac Ft.Laud,
FL
Post Number: 992 Registered: Sep-04
| Posted on Wednesday, April 20, 2005 - 12:34 am: |
http://www.etronics.com/product.asp?stk_code=sourub3002&store=&catid=303 300 watt rms @ 14 volts 4 ohm bridged or somewhere around 250 at 12.5v. I own one. Its an older amd IMO "better", discontinued model and powered my 10w3's pretty good darn good when I gave it a go. I bought it primarally as a mid/high amp so if you you plan on eventually upgrading your sub/amp it'll do great on a set of components(75x2 @ 12.5 volts 4 ohms). That thing listed at nearly 400 bucks and is a steal at $99. Etronics doesn't sell used or refurbished items so as far as a good "bang for a buck" amp I think its hard to beat. -Fishy |
Post Number: 94 Registered: Apr-05
| Posted on Wednesday, April 20, 2005 - 07:49 pm: |
any other suggestions im just looking right now until i get the sub. it is an Atlas 12" 250-300 rms nobody knows for sure. whats the best amp out there in this rms range for under $200? |
Gold Member Username: Fishy
Tamarac Ft.Laud,
FL
Post Number: 1001 Registered: Sep-04
| Posted on Wednesday, April 20, 2005 - 08:58 pm: |
There's tons of good stuff out there. Which is "best" is pretty subjective. Just stay away from the flea market stuff. Here a list that might help: http://www.caraudiocentral.net/forums/showthread.php?t=32 For two hundred dollars you might be able to pick up a good used monoblock which produces 600w at 2 ohm and 300w at 4. That way you'd be set for power if you ever wanted to upgrade: Like this: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64573%26item%3D5769134386 %26 or this: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18796%26item%3D5768941714 %26 I've seen a few new, discontinued 600w Xtant A6001's(titanium color/edition) floating around ebay for around $200 which would work good as well. -Fishy |
Gold Member Username: James1115
Wilton,
Ct
Post Number: 2392 Registered: Dec-04
| Posted on Wednesday, April 20, 2005 - 09:50 pm: |
for a good clean power under $200 honestly this is one of the best amps ever made! http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4950%26item%3D5767860225% 26%26 |
Post Number: 98 Registered: Apr-05
| Posted on Wednesday, April 20, 2005 - 10:42 pm: |
im having trouble finding the PPI are series, ebay only has 1. Where could i find more, what other amps would be great for a 12" Atlas? |
