Thread: MOST EFFIECNT AMPS 500-700RMS? |
| Posted on Tuesday, April 19, 2005 - 06:37 pm: |
im lookin for an amp that will push anywhere between 500-700rms what is the most efficent in this rms range? i have about 60amps to work with thx! |
Gold Member Username: Subfanatic
Walton,
Ky
Post Number: 2366 Registered: Dec-04
| Posted on Tuesday, April 19, 2005 - 06:49 pm: |
i have an interfire IB2900c amp that has a 50 amp current draw and is 550 watts rms bridged at 2 ohms |
Silver Member Username: Suleman36
Post Number: 710 Registered: Feb-05
| Posted on Tuesday, April 19, 2005 - 08:03 pm: |
I have a zapco 500m referance mono amp that is 40A. Puts out 500 x 1 @ 4ohms and 700 x 1 @ 2ohms and a jl 500/1 is efficiant and puts out about 600 watts rms and has a about a 50A fuse. |
Bronze Member Username: Xtant1001
Post Number: 24 Registered: Apr-05
| Posted on Wednesday, April 20, 2005 - 02:18 am: |
I have my XTANT 1001 which puts out 1000watts that im getting rid of. I bought if for 1200.00 and asking 600.00 for it. It is in mint condition and still have warranty on it. call me (425) 985-5415 or email unan0@hotmail.com if interested.
NorthWest,
Michigan
Post Number: 7654 Registered: Dec-03
| Posted on Thursday, April 21, 2005 - 06:51 pm: |
anything class D is going to be about the same, ~80% efficiency. I hope you meant 60A just for the amplifier and not a 60A alternator.
| Posted on Thursday, April 21, 2005 - 08:42 pm: |
ya glass i got a 105amp alternator if i was using 700rms would there be any problems you think? |
Post Number: 762 Registered: Feb-05
| Posted on Thursday, April 21, 2005 - 08:45 pm: |
You should be ok anonymous with that size alternator for sure. Im working with 80A and im gonna be running 850-900rms so we will see how it works out. Im using a batcap model 800 stereo battery for backup. |
NorthWest,
Michigan
Post Number: 7681 Registered: Dec-03
| Posted on Friday, April 22, 2005 - 03:00 pm: |
a: if that's 105A stock rating, your car probably uses most of that already for things like heated seats, AC, wipers, lights, fuel injection and ignition, etc. b: if it'll work will totally depend on how hard you push that amp. 700wRMS is 70A of current, which is a lot of drain on a 105A alternator. now 70A is at peak output though, so if you're not going to drive the amp hard, it will draw much less than that and yeah you may be fine.
Post Number: 771 Registered: Feb-05
| Posted on Friday, April 22, 2005 - 03:26 pm: |
Seems like you have no choice these days but to upgrade from the stock alternator if you play your systems loud and have the volume high. One question i had was like what is considered keeping the volume and draw down?? Like lets say for an alpine deck..0-35 volume. What is considered average listening and what is pushing the amp hard?? I use to keep my alpine around 17-20 average. |
