Thread: 1500 watt Boss Riot Amp |
New member Username: Mader114
Post Number: 1 Registered: Apr-05
| Posted on Tuesday, April 19, 2005 - 12:39 pm: |
I was just wondering I have a 1500 watt Boss Amp and it was working great wit my 2 rockford hx2's but one day i was driving home and they went out for like 20-30 min then i shut the car off went and looked at all the fuses and they were fine so i went back in and tryed them again and they started to work again but only for about 5 minutes i was wondering what could it be or what should i do to get it working again |
Gold Member Username: Carguy
Post Number: 2402 Registered: Nov-04
| Posted on Tuesday, April 19, 2005 - 12:49 pm: |
Check your gain/level setting. It could be that the amp is getting overloaded. It should be set properly according to your HU. Also check your speaker wires for short. Was the amp hot when it shut down? FYI, Boss amps aren't that high in quality.
Post Number: 2 Registered: Apr-05
| Posted on Tuesday, April 19, 2005 - 12:56 pm: |
It wasnt really hot but it kinda had one of those smells but i mean it still worked and i have a remote in the front to turn it down but i had it almost all the way down and it still shut off i just dont wanna have to buy a new amp becuase my system is worth more than my car lol and i dont feel like sticking more money into it so ya what else could i do |
Post Number: 2405 Registered: Nov-04
| Posted on Tuesday, April 19, 2005 - 01:02 pm: |
I'd check the gain/level control then. That is the only way an amp will get over driven. Make sure it's set half way for 4v HU (assuming the Boss amp has 8v max setting). |
Post Number: 4 Registered: Apr-05
| Posted on Tuesday, April 19, 2005 - 01:07 pm: |
k thanks ill try that
Bronze Member Username: Jeze
Post Number: 30 Registered: Jan-05
| Posted on Tuesday, April 19, 2005 - 02:51 pm: |
Hey Matt, do u feel as though your 1500 watt Boss Riot Amp performs at its ratted power which is 1500 watts rms for the Boss Riot 2500D (I'm assuming that you have this)? |
Post Number: 2412 Registered: Nov-04
| Posted on Tuesday, April 19, 2005 - 03:13 pm: |
Sean it's not matter of getting 1500w rms out of an amp. What's more important is, how much distortion/clipping is mixed in. That will destroy the subs. Depending on the severity, it can burn out a sub in matter of minutes or months. This is why the pros never ever waste their money/time on Boss/Pyramid/Sony/Lanzar/Pyle/Hifonics etc.
