Thread: HELP! |
New member Username: Nick_brown
Post Number: 4 Registered: Apr-05
| Posted on Monday, April 18, 2005 - 09:49 pm: |
Is there any way that I can hook a 8 Ohm 300 watt PA to a 4 Ohm 1200 watt amp car stereo with out blowing it? |
Silver Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 307 Registered: Feb-05
| Posted on Monday, April 18, 2005 - 10:02 pm: |
you'll either blow the sub or burn up the amp |
Post Number: 5 Registered: Apr-05
| Posted on Monday, April 18, 2005 - 10:23 pm: |
i couldn't use a resistor? |
Stockbridge,
GA
Post Number: 310 Registered: Feb-05
| Posted on Monday, April 18, 2005 - 11:19 pm: |
i'm sure you could, but i'm not sure how a larger than 4 ohm load on an amp affects it other then its output wattage. |
Bronze Member Username: Treeguy2oo4
Phoenix,
Arizona
Post Number: 32 Registered: Feb-05
| Posted on Friday, April 22, 2005 - 12:13 am: |
bro you will lose power to the sub. 1/2 the power . |
