Home > Message Board > Car Audio > Amplifiers > Archive through April 20, 2005 > Distribution blocks?
Author Thread: Distribution blocks?
Username: Msully701
Stratford, Connecticut
US
Post Number: 44
I was looking into 1 of these because it makes it easyre to wire the power/ground for 2 amps. what I want to do is get 1 D block that can take a 4 guage power wire and turn it into two 4 guage power wires for both amps and I want the same for the ground. so I want it to split the power and the ground for both amps so I only ground 1 wire and only have to run 1 power wire from my battery. I was wondering if this would work for that http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=50550%26item%3D5767806471 %26
Username: Byrumjr
Post Number: 200
When you say take a 4-gauge power wire and turn it into two 4-gauge power wires for both amps. If each amp need 4-gauge wire then you should run 1 gauge or bigger from the battery to the D-block. The link you gave looks like that will work it has any gauge input and two 4 gauge outputs. For the ground you can get D-blocks without fuses. Look at this D-block it has both hot and ground in one block.
http://www.crutchfield.com/S-VCpxP4vU4G5/cgi-bin/ProdView.asp?i=211CBR44A&search =211cbr44a
Username: Msully701
US
Post Number: 58
hey I went with two of these instead http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=50550%26item%3D5767972758 %26
will that work 1 for my power and 1 for my ground?
Username: Byrumjr
Post Number: 202
That looks fine to me. It does not say if it has a fuse in it or not. But your amp should have a fuse in it and the in-line fuse at the battery.
Home > Message Board > Car Audio > Amplifiers > Archive through April 20, 2005 > Distribution blocks? [ « Previous ] [ Next » ]
