Thread: Can i do this |
Bronze Member Username: Cenus
Hicksville,
Ohio
Usa
Post Number: 53 Registered: Jan-05
| Posted on Monday, April 18, 2005 - 07:28 pm: |
right now i have my amp mono to my 2 subs i wanna know can i still use the left and right channel while still having my other subs on mono like hooking up 4 subs {1 one the left channel 1 on the right channel and 2 mono} and if i can will they still put out the same amount of power the amp is a kicker kx600.2 if that makes a difference |
Bronze Member Username: Msully701
Stratford,
Connecticut
US
Post Number: 47 Registered: Apr-05
| Posted on Monday, April 18, 2005 - 08:09 pm: |
im guessing you mean kicker kx600.1 dont think kx600.2 exists |
Hicksville,
Ohio
Usa
Post Number: 54 Registered: Jan-05
| Posted on Tuesday, April 19, 2005 - 02:18 pm: |
my bad i just checked the amp its like 550 or 500 watts and it is 2 channel so will my idea work |
Hicksville,
Ohio
Usa
Post Number: 55 Registered: Jan-05
| Posted on Tuesday, April 19, 2005 - 08:50 pm: |
bump |
Rick Herrera Unregistered guest |
| Posted on Wednesday, April 20, 2005 - 03:25 pm: |
I have a 500 Watts Rocksford Fosgate amp and I want to know if it will pick up a 800 watts sub |
