Thread: Bandpass box |
sam griffin Unregistered guest |
| Posted on Monday, April 18, 2005 - 07:19 pm: |
if you get a bandpass box and it sounds sh*tty, can you just plug up the ports wit somthin or buy a whole new box?? |
Silver Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 306 Registered: Feb-05
| Posted on Monday, April 18, 2005 - 09:25 pm: |
a bandpass box will usually sound shi tty unless it was designed for the subs in it. if you plug the ports i'm not sure what it'd do because then it'd be sealed front and back.... |
| Posted on Tuesday, April 19, 2005 - 12:21 am: |
will pluging the port holes help at all?? please leave any information you know |
Bronze Member Username: Jthree
Bay area,
Ca
Usa
Post Number: 31 Registered: Apr-05
| Posted on Tuesday, April 19, 2005 - 01:04 am: |
is it one of those stupid a$$ plexiglass ones? i dont know what to do but it would be cool to just cut the plexiglass off then plug the holes. i dont know maybe that would work |
Stockbridge,
GA
Post Number: 318 Registered: Feb-05
| Posted on Tuesday, April 19, 2005 - 08:01 am: |
yeah, the plexi ones never stay sealed, if you take off the plexi and plug the holes, you'd basically have a sealed box and it might sound better, but it will be a very small sealed box. so it depends on the subs i guess |
