Home > Message Board > Car Audio > Amplifiers > Archive through April 20, 2005 > 4ga or 8ga for 250w rms amp
Author Thread: 4ga or 8ga for 250w rms amp
Username: Kkmike
Post Number: 28
I'm looking at an amp which is 250W RMS @ 4 Ohms and 500W RMS at 2 Ohms. It has 4 gauge connectors. My question is can I still use the 8 gauge wire I already have in the car? What is the consequence (if any significant) to using "under powered" wire?
Thanks,
Mike
Username: Carguy
Post Number: 2381
You should be fine with 8gauge power wires for your current amp.
Home > Message Board > Car Audio > Amplifiers > Archive through April 20, 2005 > 4ga or 8ga for 250w rms amp [ « Previous ] [ Next » ]
