Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Difference between Deh p7700 and Deh ...
Author Thread: Difference between Deh p7700 and Deh p860MP?
Username: Bnd_rulez
Phoenix, AZ
Post Number: 382
I don't see any real discernable diference except one has a better OEL screen. Why is the 860MP like $100 more the P7700?
Username: Illuminator
Post Number: 95
I think the key difference between the two is the fact that the 860MP has a 24 bit Burr-Brown D/A converter. Also, it steps up to 4v preouts as opposed to the 2.2v on the P7700.
Username: Minime
Portland, OR
Post Number: 36
actually, the 860 has 6.5V preouts.
Username: Minime
Portland, OR
Post Number: 37
Here's the spec sheets for both to compare.
DEH-P7700MP
DEH-P860MP
Post Number: 96
Odd...the Pioneer website says 6.5v but Crutchfield says 4v.
Username: Bnd_rulez
Phoenix, AZ
Post Number: 419
What do DAC's do? DAC means digital to analog convertor right? Would it be better to have a deck with just analog?
deepakhj
You are probably confusing the Premier model with the normal. The normal models have 4V, the premier decks have 6.5V.
Post Number: 119
Ah, thanks for the clarification. :-)
Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Difference between Deh p7700 and Deh ... [ « Previous ] [ Next » ]
