Home > Message Board > Car Audio > Amplifiers > Archive through April 20, 2005 > 3 JL Audio 15W6 DVC
Author Thread: 3 JL Audio 15W6 DVC
Username: Jstylevip
Misawa
Japan
I have 3 15W6's...and I just purchased another one. Should I purchase 2 JL Audio 500/1 and run the speakers in parallel or buy one JL Audio 1000/1??? I am currentlt running 2 15W6's on an Orion Xtreme 9002 amp...any suggestions...thanks
Username: Jstylevip
Misawa
Japan
What about 3 15's wired in series to create a 4ohm load....My Orion amp is stable at 4ohms bridged. Do you think can handle the power of 3 subs without blowing?
Username: Fishy
Tamarac Ft.Laud, FL
Post Number: 993
Subs don't create power. They're electromechanical transducers which simply means they convert electrical energy from an amplifier to mechanical then acoustic output.
I'd think 3 15w6's off a decent sized Orion would sound good...... if you got room enough for the box that is.
:P
-Fishy
Username: Fishy
Tamarac Ft.Laud, FL
Post Number: 994
Oh and it would be better to wire the voice coils in series(3 12 ohm subs) and then wire the subs in parallel for a 4 Ohm mono load.
http://www.jlaudio.com/tutorials/wiring/index.html#3dvcsp
5th diagram down from the top.
-Fishy
Username: Jstylevip
Misawa
Japan
thanks for the diagram, but I already had it. I have 4 JL audios but I plan on selling the 4th one. The amp I got is 900W rms at 4ohms, so it should be ok.?
Home > Message Board > Car Audio > Amplifiers > Archive through April 20, 2005 > 3 JL Audio 15W6 DVC [ « Previous ] [ Next » ]
