Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2005 > Good amp for either the jl W7 ,W6v2 ...
Author Thread: Good amp for either the jl W7 ,W6v2 or the kicker L7
Username: Mcazayoux
New roads, La
United states
Post Number: 20
what would be a good amp for these 3 subs and any ideas on which 1 2 get?
Username: Subfanatic
Walton, Ky
Post Number: 2175
id personally go with the w6v2, but the 1000/1 for them if i were you
Username: Mcazayoux
New roads, La
United states
Post Number: 23
hey sub y the w6v2
Walton, Ky
Post Number: 2385
cause its spl, isnt tooo far off from the w7, and its sql is way better across the board
whats good amp for 2 w7?
Username: Mcazayoux
New roads, La
United states
Post Number: 55
im not sure if i can get enough money 4 the 1000/1. what r a few other good amps for either 2 or 4 W6v2s?
Username: Mcazayoux
New roads, La
United states
Post Number: 59
i was looking at the RF 1000. how is that amp?
Username: Suleman36
Post Number: 756
For the JL 10W7 go with the jl 500/1
For the W6v2 go with the jl 500/1
I whould use the 500/1 for those to subs. Not to sure about the kicker because i dont know the size you want and rms. I am experienced with the jls cause ive owned just about all of them.
Username: Mcazayoux
New roads, La
United states
Post Number: 61
Thanx. i forgot to update this but subfanatic talked me into the w6v2s. im either going with or 4 im not sure yet. but do u still suggest that same amp? and do you have any other suggestions on amps just in case i cant get the money for the JL?
Username: Jonathan_f
GA
Post Number: 3732
For the JL W6v2s, I always liked the Kicker KX800.2 or the newer 850.2 for them, great match IMO.
Username: Suleman36
Post Number: 759
go with the jl 500/1 and if you cant afford that then look into the kicker kx 600.1 or jbl 600.1 or a mtx mono amp that puts out 500wats rms.
Username: Mcazayoux
New roads, La
United states
Post Number: 63
can those amps power 2 w6v2s?
GA
Post Number: 3734
That's what I was recommending it for.
It will put out 200Wx2 at 4 ohms on each channel, 400x2 on 2 ohms, and 800x1 on a 4 ohm bridge, which either way matches perfectly to one or two W6v2s, at least the 10" and 12" models.
Username: Mcazayoux
New roads, La
United states
Post Number: 64
thanx. what do you think about those subs? you think theyll pound?
Username: Suleman36
Post Number: 760
See michael i wish you had been more detailed with your description the first time. So you wanna power 2 subs and not 1 right? if thats so then go with the PPI PCX 2200 that im selling right now. Its a hell of a deal right now for 200.00 on ebay. If you want go and check it out. Just search for ppi pcx 2200. It does 200 x 2 @ 4 ohms and 400 x 2 @ 2 ohms and 800 x 1 @ 4 ohm bridged. Much better then that kicker IMO. YOu can check with jonathan or isaac if you want. I paid $800 when it first came out. I own 2 12w6v2's sealed in the jl prowedge box and i ran them off my ppi pcx 2200 that im selling. It sounded great and hit hard. Check it out on ebay
Username: Mcazayoux
New roads, La
United states
Post Number: 67
cool, thanx ill check into it what brand is that?
Username: Mcazayoux
New roads, La
United states
Post Number: 69
and whats your reserve on it?
Username: Suleman36
Post Number: 763
NO RESERVE and its PPI PCX 2200. It is the 2003 model and is much better then any kicker amplifier in that class. PPI stands for Precision Power by the way. Ask anybody about them
Username: Mcazayoux
New roads, La
United states
Post Number: 71
thanx it looks good
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2005 > Good amp for either the jl W7 ,W6v2 ... [ « Previous ] [ Next » ]
