Thread: Amp watt= Sub watt or??? |
Bronze Member Username: Tpizzle
Post Number: 54 Registered: Apr-05
| Posted on Sunday, April 17, 2005 - 07:11 pm: |
When comparing amp watts (both rms and peak) to sub watts (same), should they be the same, or should one put out or handle more power than the other? |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 375 Registered: Mar-05
| Posted on Monday, April 18, 2005 - 07:56 am: |
Throw "peak" "dynamic" "maximum" ratings out the window. You are going to want to match rms on the amp to the rms on the sub. |
NorthWest,
Michigan
Post Number: 7640 Registered: Dec-03
| Posted on Monday, April 18, 2005 - 03:04 pm: |
look at RMS power ratings only, and you want the subs to be 80-100% of the RMS rating of the amplifier, generally. there are always exceptions, like audiobahn who outrageously overrate their products.. they have 1600 watt subs, but those really only need about 300-500 watts to reach peak output.
NorthWest,
Michigan
Post Number: 7641 Registered: Dec-03
| Posted on Monday, April 18, 2005 - 03:08 pm: |
let me restate that. it sounds confusing after I raed it again. if the sub is rated to accept up to 100 watts RMS, the amp should be about 80 watts RMS. the RMS rating of an amp is the output of the amplifier, continuous, at peak output. the RMS power rating of a speaker is a thermal rating that tells you how much heat measured in watts, that the voice coils can take without melting. a speaker's power handling varies a lot based on the enclosure type, but as a rule of thumb, if you don't know any better, never give the sub more than it's RMS rated power handling.
Post Number: 76 Registered: Apr-05
| Posted on Monday, April 18, 2005 - 09:31 pm: |
thanks for the help glasswolf |
