Thread: No remote power wire from head unit |
New member Username: Pphillips21
UK
Post Number: 1 Registered: Apr-05
| Posted on Sunday, April 17, 2005 - 04:09 pm: |
i have no remote power wire from the back of my head unit and my amp doesnt seem 2 work without what can i do about this?? thanx |
UK
Post Number: 2 Registered: Apr-05
| Posted on Sunday, April 17, 2005 - 04:30 pm: |
i really need sum help here
Silver Member Username: Sony224422
Deep River,
CT
US
Post Number: 149 Registered: Dec-04
| Posted on Sunday, April 17, 2005 - 05:09 pm: |
find either a power wire in your fuse box that is on when the accesories turn on, or you can look for the power antenna on your head unit if it has one. And yes, your amp needs the remote to turn on, its what tells it to turn on or off. If you can't find either, you can run a wire to the battery, and to a switch, and from the other post on the switch to your amp. If you use a swicth though, you'll always have power to your amp whether the cars on or off so you'll have to make sure your switch is off when the car is off. |
UK
Post Number: 3 Registered: Apr-05
| Posted on Sunday, April 17, 2005 - 05:40 pm: |
what voltage do u need for it 2 work??
mattjk88 Unregistered guest |
| Posted on Monday, April 18, 2005 - 06:33 am: |
So you can just replicate a remote turn on signal with a 12v power supply? |
Deep River,
CT
US
Post Number: 151 Registered: Dec-04
| Posted on Monday, April 18, 2005 - 01:52 pm: |
all the voltage in the car is the same. and yea you can just replicate one. |
New member Username: Buchanan
| Posted on Monday, April 18, 2005 - 06:16 pm: |
you could just connect the remote wire to your speakers in the front or back. as long as they are off when the ignition is switched off. thats what i am going to do on mine because i dont have a remote power wire in my head unit. |
