Thread: Can my amp. handle it??????? |
Unregistered guest |
| Posted on Sunday, April 17, 2005 - 12:31 am: |
hi my name is shawn ballinger i have 2 w3v2 15" subwoffers and a 1000/1 mon block JL AUDIO. i would like to buy a 3rd sub. i dont know the watts or oms of the 2. but i have been told that if i buy the 3rd sub (some as the others W3V2 15)would drain or blow the amp. because of the oms or something what should i do¿?¿ thug_ak47_9@hotmail.com |
Silver Member Username: Araknid
BOCA ,
FL
U.S.
Post Number: 424 Registered: Nov-04
| Posted on Sunday, April 17, 2005 - 12:39 am: |
I dont think you should cuz its not gonna be that much louder and it might blow your amp. |
| Posted on Sunday, April 17, 2005 - 12:40 am: |
no |
BOCA ,
FL
U.S.
Post Number: 425 Registered: Nov-04
| Posted on Sunday, April 17, 2005 - 12:41 am: |
im not sure how you would wire it. |
| Posted on Sunday, April 17, 2005 - 12:44 am: |
through a mon block |
Silver Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 292 Registered: Feb-05
| Posted on Sunday, April 17, 2005 - 12:59 am: |
you could hook 3 to the 1000/1, depends on whether you have dual 2 or 4 ohm subs. if they are dual 2, wire each sub's VC in series, then each sub in paralel for a 1.33 ohm load. it should work even though the amp says 1.5-4ohm. a friend has 3 4 ohm svc subs wired to 1.33 ohms on a 500/1 and has no problems. or if the subs are dual 4, wire each vc in series, then the subs in parallel for a 2.66 ohm load. i'd think just having 2 would be better since they would receive their RMS, adding a 3rd will only give each around 330 watts. i'd stick with 2 or get a bigger amp |
| Posted on Wednesday, April 20, 2005 - 09:39 pm: |
ok ty's |
