Thread: Soundstorm amp question |
| Posted on Sunday, April 17, 2005 - 12:19 am: |
Specs- 2 Channel MOSFET Bridgeable Power Amplifier with Remote Subwoofer Level Control max power 2 ohms 800W x 2~ rms power 4 ohms 300W x 2 bridged power 1600 x 1 damping factor 125 + any good?.... if not i need another cheep solution |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 354 Registered: Mar-05
| Posted on Sunday, April 17, 2005 - 08:24 am: |
Crapp. Look at Kicker, MTX, Hifonics and SoundSTREAM for cheap/decent solutions./ |
| Posted on Sunday, April 17, 2005 - 11:08 am: |
is the sound quality bad or somthing because it looks like it puts out decent power... i think i'll prolly go with somthing more name brand like the ones you listed or jbl or somthin |
NorthWest,
Michigan
Post Number: 7621 Registered: Dec-03
| Posted on Sunday, April 17, 2005 - 12:03 pm: |
poor reliability and poor performance. never use "max power" ratings. they're meaningless made up numbers. use RMS or CEA power ratings.
Nick_sq Unregistered guest |
| Posted on Monday, April 18, 2005 - 03:35 pm: |
i put a soundstorm R280.2 In a friends car just for a little thump and it has been hitting hard for 3 years now. I agree the name sucks, but it can treat you well on a budget. The R.280.2 puts out 120 watts RMS x 2 @ 4 ohms low THD (under .5% i think) It kicks 2 orion cobalt 10's running 2 ohms stereo. Sounds pretty good too (for the price of the amp..at around 90 bucks new) The remote amp gain is a nice feature. Giver a try, 300X 2 RMS is not all that bad, but i would expect a TRUE 150-200 RMS x2...still, not bad on a budget. |
Gold Member Username: Carguy
Post Number: 2379 Registered: Nov-04
| Posted on Monday, April 18, 2005 - 03:59 pm: |
The problem with cheap amps is, they give you power with distortion/clip mixed in. Unless you have super ears, you won't be able to pick that up at high volume.
| Posted on Tuesday, April 19, 2005 - 07:21 pm: |
so then good for the money?? or should i spend the extra hundred and get somthing bettr |
Phoenix,
AZ
Post Number: 399 Registered: Mar-05
| Posted on Tuesday, April 19, 2005 - 07:25 pm: |
You get what you pay, pay extra and get something worth the money. |
Phoenix,
AZ
Post Number: 400 Registered: Mar-05
| Posted on Tuesday, April 19, 2005 - 08:01 pm: |
so what do you recommend? |
| Posted on Wednesday, April 20, 2005 - 07:54 pm: |
i need a in-expensive amp, like really in-expenisve So whats the cheapest amp thats still good (like around 600w rms) if thats possible. because thats what that soundstorm was so thats why i was considering it |
| Posted on Wednesday, April 20, 2005 - 07:57 pm: |
Phoenix,
AZ
Post Number: 438 Registered: Mar-05
| Posted on Wednesday, April 20, 2005 - 08:01 pm: |
How much do you have to spend? BTW the Soundstorm will not replicate those numbers at all, you'd be lucky to get half what they say it will achieve. |
NorthWest,
Michigan
Post Number: 7653 Registered: Dec-03
| Posted on Thursday, April 21, 2005 - 06:45 pm: |
either save more money before you buy something, or look at buying used instead of new if you're looking in the soundstorm $40 amp range. you're not going to find anything worth the money.
