Thread: Poineer Cd Player |
DaDaSuPrEme Unregistered guest |
| Posted on Saturday, April 16, 2005 - 11:00 pm: |
A friend gave me his old Pioneer head unit. It still works, but the harness that plugs right into the back of the cd player is kind of messed up. He has alot of wires spliced and some of it has barew wire showing. So I just wanted to know if I can buy another harness somewhere. Its a good cd player I just want to clean the wires up because I dont know iF I could trust what he has done. Anyone have any suggestions? Thank You |
Bronze Member Username: Illuminator
Post Number: 90 Registered: Apr-05
| Posted on Sunday, April 17, 2005 - 12:01 am: |
Ebay would be a great place to find another harness. |
| Posted on Sunday, April 17, 2005 - 12:44 am: |
Where could I find the wiring harness that would fit a DEH-10? |
Post Number: 91 Registered: Apr-05
| Posted on Sunday, April 17, 2005 - 02:49 am: |
Put this number in the ebay search box: 5768235207 and hit enter. An auction should come up with the exact harness you'll need. If that doesn't work, just search for 'pioneer wiring harness' and go through the list of those to find one that will fit your unit. |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 347 Registered: Mar-05
| Posted on Sunday, April 17, 2005 - 07:54 am: |
Your local Autozone should carry them too. And they run less then $10 |
| Posted on Sunday, April 17, 2005 - 05:33 pm: |
Thanks for the help Jexxen and David. Before I came here I was looking to pay $21 plus shipping directly from Poineer |
