Thread: Setting clock on Pioneer DEH-P2000 |
New member Username: Gatorfreak
Post Number: 2 Registered: Apr-05
| Posted on Saturday, April 16, 2005 - 04:32 pm: |
This unit was in a truck I purchased and for the life of me I can't set the clock on this unit. I don't have a owners manual. Anyone know where to get an old owners manual. |
Bronze Member Username: Illuminator
Post Number: 88 Registered: Apr-05
| Posted on Saturday, April 16, 2005 - 04:35 pm: |
I think you have to turn the unit off while the car is still on, so you can see the still see the clock. Then, hold down the function button until the hours flash. Use the four arrow keys to change the hours up and down and to advance to the minutes. When you finish setting the clock, hold the function button down again until it stops flashing. You should be able to download the owners manual in PDF format on the 'net somewhere. |
Post Number: 4 Registered: Apr-05
| Posted on Saturday, April 16, 2005 - 07:00 pm: |
Tired this suggestion but it didn't work. Thanks for the insight
Post Number: 89 Registered: Apr-05
| Posted on Saturday, April 16, 2005 - 11:59 pm: |
Did you also try the audio button? |
Post Number: 5 Registered: Apr-05
| Posted on Sunday, April 17, 2005 - 03:15 am: |
Actually this deck is strange in a way that once you turn the deck off with the car turned on the clock doen't even appear. That seems odd to me, but maybe it is my cd player. This is the first I have own that does this, and I have had several Pioneers. |
Post Number: 92 Registered: Apr-05
| Posted on Sunday, April 17, 2005 - 03:38 am: |
Ah...I don't think you need the clock to display with the unit off and car on for you to be able to set it. You should still be able to press and hold either the audio button or function button without the display lit up and the clock setting should appear. I had a Pioneer unit just like this about a year ago, and i'm trying to remember how I did it(I also remember what a pain it was to set the thing). |
Post Number: 6 Registered: Apr-05
| Posted on Sunday, April 17, 2005 - 07:37 pm: |
Thanks Jexxen it worked. It's great to actually have the right time on the clock. Thanks again
Unregistered guest |
| Posted on Sunday, May 22, 2005 - 03:06 am: |
Thank You !!! What a hassle... |
