Home > Message Board > Car Audio > Amplifiers > Archive through April 20, 2005 > A quetion about ohms
Author Thread: A quetion about ohms
Username: Beatleringo
i have 2 10" subs rated at 4 ohms. if my amp is bridgeable at 2 ohms, can i bridge it with out blowing the subs or amp?
Thanks in advance
Username: Taylor17
Kopperl, Texas
Post Number: 1363
Are they 4 ohm's dvc, or svc?
how can i tell?
Username: Volfenhag1200
Post Number: 24
does it have 2 spots on the sub to hook up wire or just one
Username: Jhonnysr7362
i have 2 performance tekniques ICBM5712DX subs. each one is:
EFICIENCY=89.58DB
RE=3.2OHNS
NOMINAL IMP=DUAL 4OHNS
RMS=500
PEAK POWER=1000. I want to match em' with a D class mono amp, my question is which amp should i get and how many watts should it produce also how should i wire the subs for a powerfull yet tight bass. low to mild budget. Can please somebody give me some advice. Thank u.
Username: Glasswolf
NorthWest, Michigan
Post Number: 7633
wire coils in series
wire subs in parallel
bridge amp
all done
Home > Message Board > Car Audio > Amplifiers > Archive through April 20, 2005 > A quetion about ohms [ « Previous ] [ Next » ]
