Home > Message Board > Car Audio > Amplifiers > Archive through April 20, 2005 > ALPHASONik amp question
Author Thread: ALPHASONik amp question
Username: Williamc
Post Number: 34
i have two 450w rms subs(ed 11ov.2) and need aroudn 900w to run them. i cant seem to find an amp that matches perfectly. im between the hifonics bx1000, or i qwas looking at this one...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4950%26item%3D5767622121& tc=photo
i dont knwo much about alphasonik but it says its a class a/b so it must be decent... any suggestions on which amp?
Username: Williamc
Post Number: 35
anyone??
Username: Subfanatic
Walton, Ky
Post Number: 2091
what ohms are the subs? and if you can run them at 2 ohm mono, then your set, get the ednine.1, same brand as your subs, would look slick together, and is 900 watts rms at 2 ohms mono lol
Username: Williamc
Post Number: 36
well i havnt ordered the subs yet so im not sure wether or not to go dual 2 or dual 4. and the ed nine is back ordered. so i was thinking about running the hifonics bx1200 which is 900w@2ohms. but can i run 900w off of a tsunami 4gauge bat. cable? thanks
Username: Fishy
Tamarac Ft.Laud, FL
Post Number: 961
Sure, if it ain't an extrordinarily long run of 4 gauge and your alternator is keeping up.
-Fishy
Home > Message Board > Car Audio > Amplifiers > Archive through April 20, 2005 > ALPHASONik amp question [ « Previous ] [ Next » ]
