Thread: Need ADVICE On Best Head Unit For Under 200$ |
Bronze Member Username: Vincentian
Post Number: 15 Registered: Apr-05
| Posted on Friday, April 15, 2005 - 10:31 pm: |
hi... need advice on the best head unit for under 200 dollars ... ne input would be helpful thanks |
Gold Member Username: Invain
Michigan
United States
Post Number: 2034 Registered: Aug-04
| Posted on Saturday, April 16, 2005 - 12:33 am: |
The lower Alpine models. Just look for ones with 982 as the first 3 of the 4 numbers in the model number. |
Post Number: 16 Registered: Apr-05
| Posted on Saturday, April 16, 2005 - 12:38 am: |
aite thanks |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 345 Registered: Mar-05
| Posted on Sunday, April 17, 2005 - 07:51 am: |
Theres nothing wrong with Pioneers either. Before you buy, go to an audio store and demo some head units and check out which ones have the best optins that you like, then buy them online if the store won't match the price. |
