Thread: !!!HELP PLZZ!!! 800rms amp! |
Bronze Member Username: Chenzevy
Post Number: 60 Registered: Mar-05
| Posted on Friday, April 15, 2005 - 09:44 pm: |
ive been searchin for hours everywhere and cant find a 800rms amp at 1ohm. i just need to find a high quality amp. as soon as you guys suggest some im orderin an avalanche. my price limit is $600 i want the best thank you |
Gold Member Username: James1115
Wilton,
Ct
Post Number: 2345 Registered: Dec-04
| Posted on Friday, April 15, 2005 - 11:17 pm: |
Orion HCCA 250 g4 does 800x1 @1ohm and you can get it for half that price |
Silver Member Username: Fishy
Tamarac Ft.Laud,
FL
Post Number: 918 Registered: Sep-04
| Posted on Friday, April 15, 2005 - 11:36 pm: |
Just use a 1000 watt monoblock and be careful with the gains. You might also look for a big 2 channel amp and run the vc's in series for a bridged 4 ohm load although going A/B instead of class D will probably put extra demands on your alternator. -Fishy
Post Number: 61 Registered: Mar-05
| Posted on Saturday, April 16, 2005 - 01:05 am: |
thanks james ans fishy you two and johnathan and glasswolf are the best posters on this messageboard you guys are so knowelegable and i always take extra time to read your guys' posts. |
Silver Member Username: Jwbulger79
Florida
Post Number: 483 Registered: Nov-04
| Posted on Saturday, April 16, 2005 - 01:28 am: |
yeah they are. i bookmark their posts  |
Wilton,
Ct
Post Number: 2346 Registered: Dec-04
| Posted on Saturday, April 16, 2005 - 02:33 am: |
well thanks man I just wish I knew half as much as the others you just mentioned. |
Gold Member Username: Invain
Michigan
United States
Post Number: 2039 Registered: Aug-04
| Posted on Saturday, April 16, 2005 - 09:41 pm: |
Lol. James, you finally have some fans. |
Wilton,
Ct
Post Number: 2356 Registered: Dec-04
| Posted on Sunday, April 17, 2005 - 03:33 am: |
thanks nick So do you buddy I am your fan |
