Home > Message Board > Car Audio > Amplifiers > Archive through April 20, 2005 > Red protection light on an orion coba...
Author Thread: Red protection light on an orion cobalt 200.4 amp???
Username: Faisal
I don't get it, I have two amps, my orion and a jbl 180.1 watt. the jbl for my two JL subs 12.01 works just fine, the orion amp has the protection light is always red.(even when the car is off, the key is out of the...)
the 4 channel 200 watt amp has 2 speakers running at 75 watts rms and 2 running at 50 watts rms. both my amps have the same remote and power source.
Note: I grounded both my amps together.
What can it be,
thank you for any advice
Faisal
Username: Glasswolf
NorthWest, Michigan
Post Number: 7576
could be a failed amplifier.
disconnect the speakers completely and see if the light stays on.
Username: Volfenhag1200
Post Number: 25
try the rem wire mine did that because the rem wire wasnt hooked properly
Home > Message Board > Car Audio > Amplifiers > Archive through April 20, 2005 > Red protection light on an orion coba... [ « Previous ] [ Next » ]
