Thread: What do i use for a remote wire |
New member Username: Devin_wyngard
Greenville,
Wi
Usnited states
Post Number: 5 Registered: Apr-05
| Posted on Thursday, April 14, 2005 - 10:48 am: |
i a hooking up my rear 6 by 9 speakers in the back on an amp. but i do not know what to use ro a remote wire? |
Bronze Member Username: Krijgy
Smithfield,
Virginia
United states
Post Number: 81 Registered: Jan-05
| Posted on Thursday, April 14, 2005 - 10:50 am: |
do you mean a remote wire for your amp to your cd head? cause there is no wuch thing as a remote wire that runs from the speaker to the amp. |
Gold Member Username: Invain
Michigan
United States
Post Number: 1975 Registered: Aug-04
| Posted on Thursday, April 14, 2005 - 12:03 pm: |
Remote wire, or speaker wire? |
Gold Member Username: Taylor17
Kopperl,
Texas
Post Number: 1347 Registered: Jan-05
| Posted on Thursday, April 14, 2005 - 06:40 pm: |
or are you talking about a remote gain wire... |
Bronze Member Username: Kaos15th
Phoenix,
Arizona
Post Number: 13 Registered: Mar-05
| Posted on Thursday, April 14, 2005 - 09:34 pm: |
LoL hes talking about the blue remote wire from the back of the head unit to the amp . you can use speaker wire for that. |
Greenville,
Wi
Usnited states
Post Number: 7 Registered: Apr-05
| Posted on Friday, April 15, 2005 - 10:10 am: |
yea but i dont want to run new wires because i am hooking up a second amp sorry if i didnt make that clear enoughf before |
Silver Member Username: Fishy
Tamarac Ft.Laud,
FL
Post Number: 913 Registered: Sep-04
| Posted on Friday, April 15, 2005 - 10:41 am: |
Just run the remote wire off your other amp. -Fishy |
Bronze Member Username: Volfenhag1200
Post Number: 22 Registered: Mar-05
| Posted on Sunday, April 17, 2005 - 04:01 pm: |
any copper wire will work it doesnt matter how old or new it is. just find some old copper wire and use it. |
Silver Member Username: Sony224422
Deep River,
CT
US
Post Number: 150 Registered: Dec-04
| Posted on Sunday, April 17, 2005 - 05:16 pm: |
I did that, i used indoor electrical wire, big whoop i have like 10,000 ft of it on a spool so why bother paying for special car audio wire when its the same stuff. Anyways just run another wire from the amp with the remote wire to the other amp. thats all i did and it worked fine. |
Bronze Member Username: Mixneffect
Orangevale,
Ca.
Post Number: 43 Registered: Apr-05
| Posted on Sunday, April 17, 2005 - 06:04 pm: |
Guys, Guy, Guys !!! If you're gonna give advise, please take in consideration the copy of a copy effect. When you make a copy of a copy and then use that copy to make another copy, and repeating this process over and over again... the next thing you know is that you have a copy that is no where close to the original. Take the safe bet, and follow proven steps. When it calls for a specific wire, use that specific wire, otherwise you will end up with another problem. By the way; for power wires, AC circuitry require solid strand wire, while DC circuitry require stranded wire. There is a reason for this. Please don't try to re-invent the wheel, and/or get away with stuff by taking shortcuts. |
Deep River,
CT
US
Post Number: 152 Registered: Dec-04
| Posted on Monday, April 18, 2005 - 01:54 pm: |
its the same thing. its carrying such little power that it doesn't matter. it works. it might not be the best thing, but it works. |
