Thread: Speaker amp |
New member Username: Tpizzle
Post Number: 9 Registered: Apr-05
| Posted on Wednesday, April 13, 2005 - 01:45 pm: |
i need a little extra kick for my speakers. i have infinity ref in the front and am thinking about gettin an amp for them. is an amp necessary and if so how important is a "good" brand since only maybe 20-40w rms is going into them? |
Gold Member Username: Invain
Michigan
United States
Post Number: 1964 Registered: Aug-04
| Posted on Wednesday, April 13, 2005 - 08:48 pm: |
What's your headunit? If your looking to upgrade that, you can find higher-end ones that have amps in the 20-40w rms range. If not, you can get small amps, like the MTX Thunder202 for like 100 bucks. |
Silver Member Username: Joebruce
KY
U.S.A.
Post Number: 220 Registered: May-04
| Posted on Thursday, April 14, 2005 - 07:36 am: |
I wouldnt bother gettin an amp for those.If you want "a little extra kick" i would upgrade to some infinity perfect components or some other components then get an amp for them. |
New member Username: Devin_wyngard
Greenville,
Wi
Usnited states
Post Number: 4 Registered: Apr-05
| Posted on Thursday, April 14, 2005 - 10:40 am: |
y woundnt you just put an amp on your 6 by 9's in the back it would sound alot better |
