Thread: Orion 1200d |
Bronze Member Username: W00b
Post Number: 42 Registered: Mar-05
| Posted on Wednesday, April 13, 2005 - 11:09 am: |
does the orion 1200d have rca out, so i could hook up another amp to it? |
Bronze Member Username: Invictuz
Seattle,
Wa
Usa
Post Number: 45 Registered: Jan-05
| Posted on Thursday, April 14, 2005 - 04:28 am: |
yes...and it is externally bridgable |
Post Number: 49 Registered: Mar-05
| Posted on Friday, April 15, 2005 - 03:53 am: |
thats cool.. can someone recommend some other amps that are like this one? class d and high rms rating.. rca out and externally bridgable? |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 327 Registered: Mar-05
| Posted on Friday, April 15, 2005 - 06:43 am: |
Get another Orion? |
Post Number: 50 Registered: Mar-05
| Posted on Friday, April 15, 2005 - 10:47 am: |
yeah.. but ive seen other people using RF or JBL 1000/1.. i just want more of a variety you know? help if you can. |
Post Number: 51 Registered: Mar-05
| Posted on Friday, April 15, 2005 - 10:52 am: |
wow im an idiot, i meant JL 1000/1 |
Post Number: 57 Registered: Mar-05
| Posted on Saturday, April 16, 2005 - 12:48 am: |
ok..maybe there aren't any other suggestions then.. lol, the orion 1200d seems fine to me, i thought you guys would have plenty of other suggestions though. |
Seattle,
Wa
Usa
Post Number: 46 Registered: Jan-05
| Posted on Sunday, April 17, 2005 - 05:26 am: |
I have four T81044a MTX 10" subs in four .50 sealed enclosures. I have four RF farad capacitors. I had four RF 301m 300w monoblock amps; one for each sub. I was lead to believe that having four seperate amps was not ideal so i decided to consolidate and purchased an Orion 2500d to replace the four 301m's. After a two months of trying to achieve the same clarity and impact in bass (including talking with DEI, Authorized dealers and other knowledgable sources) i am almost ready to yank the Orion and reinstall the 301m's. i just received a 205amp alternator which i am hoping will improve the Orions output. Thus far my experience with Class D amps is not encouraging...Class A/B seems to produce a cleaner, tighter bass...
