Thread: Power draw and quick fuse ? |
Bronze Member Username: Langless28
Post Number: 80 Registered: Dec-04
| Posted on Wednesday, April 13, 2005 - 11:08 am: |
i have roughly 800 max watts system im am puttin my 97 cherokee sport and i was wondering if that much power draw would affect anything. i.e. dim lights, etc. also. on my amps, they have a 20 amp fuse for the first and dual 25 amp fuse for the seond. for the main agu fuse on the 4ga power wire, should i get a 45 amp fuse or higher? |
NorthWest,
Michigan
Post Number: 7562 Registered: Dec-03
| Posted on Wednesday, April 13, 2005 - 12:29 pm: |
what are the RMS ratings of the amplifiers at the loads you're running? (2 ohm, 4 ohm..)
Post Number: 83 Registered: Dec-04
| Posted on Thursday, April 14, 2005 - 09:33 am: |
50x4 4ohms for interior speakers and something like 200-230 rms 4 ohm for the sub |
Bronze Member Username: Nitescort
Post Number: 55 Registered: Mar-05
| Posted on Friday, April 15, 2005 - 09:45 am: |
I think a yugo could easily power that system. you should have no problems. |
