Home > Message Board > Car Audio > Amplifiers > Archive through April 15, 2005 > How many watts can a sub take?
Author Thread: How many watts can a sub take?
Dean 87
If a 15" sub is 600 Watt RMS Power 1200 Watt Peak Power. Then how many watts can it take?
Username: Theelfkeeper
Stockbridge, GA
Post Number: 279
it'll take 1200 watts of clean power, depending on the brand. some are underrated, some are overrated.
Username: Mad_at_madd
Chico, CA
Post Number: 12
Brandon is correct however it should be stated that those speakers can only handle anything over 600 watts for short periods of time. The speaker will not handle a continuous 1200watts and will blow if you try.
Username: Glasswolf
NorthWest, Michigan
Post Number: 7549
the RMS power handling tells you how much continuous power the speaker can handle without thermal damage.
the peak rating tells you how much the coils can handle in a burst without melting.
generally match the RMS rating of the sub to the RMS rating of the amp, at the given load.
Home > Message Board > Car Audio > Amplifiers > Archive through April 15, 2005 > How many watts can a sub take? [ « Previous ] [ Next » ]
