Thread: Wiring a Head Unit |
HandBlown0990 Unregistered guest |
| Posted on Tuesday, April 12, 2005 - 03:36 pm: |
My buddy has a cd player for sale. But, there isnt any wires coming out of it. He says u can just go pick the harness up and thats all there is to it. Is it really just that easy or should I consider looking somewhere else? |
NorthWest,
Michigan
Post Number: 7540 Registered: Dec-03
| Posted on Tuesday, April 12, 2005 - 06:01 pm: |
I wouldn't buy a head unit without the wiring harness unless you already know where to get the exact harness for that make and model of stereo.
| Posted on Tuesday, April 12, 2005 - 08:25 pm: |
Do you know the speaker wiring diagram for a PIONEER DEH-P3600? I can't find my wiring diagram. Thank you. The colors of the wires are...White/Grey/Purple/Green there are two of each....one of each has a black stripe...I'm sure that the blak stripe is my negitive. |
| Posted on Sunday, April 17, 2005 - 11:09 am: |
Hey listen i put an after market head unit in my 94 jeep wrangler i hooked it up just the way it was supposed to be, now my jeep wont start, i have replaced the battery, the fuel filter,distributor cap, halifax,coil,crank sensor,fuel pump relay and i think thats it, what could be the problem, it will turn but not all the way over it just keeps cranking |
