Home > Message Board > Car Audio > Amplifiers > Archive through April 15, 2005 > JBL 5 1/4 two-way speakers pretty dec...
Author Thread: JBL 5 1/4 two-way speakers pretty decent?
Username: Bass_buster_bob
Post Number: 17
i just got a couple for the front doors of my 94 grand prix. The guy at the store told me they are made on the same assembly line as Infinity. They sound pretty good. not as much bass as pioneer, but more clean and sharp.
Username: Chungy
Australia
Post Number: 10
Should get Infinity Kappa 60.5CS splits instead.
Need bass? No problem..get a sub.
Username: Abew330
Camarillo, Ca
Usa
Post Number: 47
one 10" should be enough bass... even a 8"
Post Number: 18
i got an mtx 12" 600W mzs1204 sub but my 400W 4-chan amp doesnt make it sound too great
im not suprised a 4 channel amp was never supposed to be used on a sub. get a 2 channel bridgeable or mono
Username: Bnd_rulez
Phoenix, AZ
Post Number: 330
I would grab the Infinity's over the JBL's. YOu can get Kappas real cheap on the internet, like eBay. Crappy amps will produce crappy sound, especially if they are underpowering a sub. You can get the same sound out of a 4 channel as you can out of a 2 channel.
Home > Message Board > Car Audio > Amplifiers > Archive through April 15, 2005 > JBL 5 1/4 two-way speakers pretty dec... [ « Previous ] [ Next » ]
