Home > Message Board > Car Audio > Amplifiers > Archive through April 15, 2005 > Specification on Orion 2100 hcca digi...
Author Thread: Specification on Orion 2100 hcca digital amp
Username: Marc1
hi from downunder.
All new to this guys/girls looking for spec on Orion 2100 Hcca amp.
Found amp in a (sells & trades) shop hear in Sydney (oz).
Bought for $135.00 Aus dollars, US probably $70.00 US (lucky buy), the guy didn't know what he was selling. Amp sounds great.I paired it up with my Orion Extreme 2x100rms.
Powering MB Quart RSB 215.
Thought Hcca amp would drive DV-coil 12 nicely. All comments wellcome.
Username: Carguy
Post Number: 2300
You got yourself a steal there. That amp goes for over $450 on eBay.
The 2100hcca is rated at 100x2@4ohm; 200x2@2ohm; 400x2@1ohm
Bridged: 400x1@4ohm; 800x1@2ohm; 1600x1@1ohm
They're all RMS power numbers. You won't find another bargin like that again.
Username: James1115
Wilton, Ct
Post Number: 2273
nope you sure wont, that is an amazing amazing deal! wow one of the best I have heard in a long time actually.
Username: Glasswolf
NorthWest, Michigan
Post Number: 7529
the 2100HCCA is 1 ohm stable stereo, 2 ohm stable bridged. peak output is 800wRMS.
great amplifier.
email me if you need to and I can send ya the manual for that amp in PDF format. I just happen to have it sitting here on a CD when I saw this.
you can get me via the link on my website listed in my profile here.
that is a class AB amp, so be sure you give it plenty of air to keep it cool. they get hot enough to burn ya if you touch one during use even at low to moderate output. I'm using three 2250SX amps now that use the same casing as that 2100HCCA, and have somewhat similar outputs. I've owned and sold a lot of Orion gear and those are still some of my favorite amps.
Username: Carguy
Post Number: 2302
Glasswolf can you email me a copy of the 2100HCCA manual in pdf? I like to keep a copy for reference.
Username: James1115
Wilton, Ct
Post Number: 2278
Hey Glass why is the HCCA 250 and HCCA 275 1ohm mono stable and the HCCA 2100 are 1ohm stereo stable?
Username: Glasswolf
NorthWest, Michigan
Post Number: 7553
not knowing which generation of HCCA amp he has, the first through third gen HCCA amps were all stable to 1 ohm stereo except for the 225HCCA which was 0.5 ohm stereo stable.
That changed with some models in later generations like the G4 and G5 lines which was around the time they were taken over by DEI and I I stopped using their stuff.
Username: Glasswolf
NorthWest, Michigan
Post Number: 7554
Isaac, email me and I'll send it. I can't attach files through the board here.
just use my nick at yahoo
Username: Marc1
Thanks so much to you all for your great responce on my amp hcca 2100.
By the way also looking for manual on orion extreme xtr 200.
Thanks again.
Username: Chungy
Australia
Post Number: 18
hell Marc you gotta find me another one of your amp. can't find that up here in woop woop Darwin. that's a steal mate well done!!
Home > Message Board > Car Audio > Amplifiers > Archive through April 15, 2005 > Specification on Orion 2100 hcca digi... [ « Previous ] [ Next » ]
