Thread: How about this? am i choosing the right stuff? |
Bronze Member Username: Terps297
Potomac,
MD
Post Number: 92 Registered: Oct-04
| Posted on Tuesday, April 12, 2005 - 07:52 am: |
is this setup quality or am i cheaping myself and should i get better stuff Alpine 9853 Diamond HEX S600s 6.5 components Ascendant 15" avalanche Soundstream VGA800.2(for av) and 600.2(for hex) knukoncepts wiring Optima red top battery 150 amp alt |
Silver Member Username: Araknid
BOCA ,
FL
U.S.
Post Number: 414 Registered: Nov-04
| Posted on Tuesday, April 12, 2005 - 09:18 am: |
Good stuff. You need a enclosure tho. |
Silver Member Username: Jwbulger79
Florida
Post Number: 453 Registered: Nov-04
| Posted on Tuesday, April 12, 2005 - 10:17 am: |
looks good. |
Potomac,
MD
Post Number: 93 Registered: Oct-04
| Posted on Tuesday, April 12, 2005 - 11:11 am: |
i've been trying to contact chad at ascendant to inqure him about having them build a box and send it with the Av. would this be the best route or should i just build my own box. |
Bronze Member Username: Abew330
Camarillo,
Ca
Usa
Post Number: 41 Registered: Mar-05
| Posted on Tuesday, April 12, 2005 - 11:49 am: |
i'll get better amps.. |
Gold Member Username: Invain
Michigan
United States
Post Number: 1933 Registered: Aug-04
| Posted on Tuesday, April 12, 2005 - 11:52 am: |
Depends on how much it costs. If you had them build just a sealed box with an Avalanche in it, I'm sure it wouldn't cost very much. I do know sometime in the future Chad want's to start building Snail Shells for the Atlas's and Avalanche's. When you find out whether they can build one for ya, tell me, because I'd rather them build one than myself. |
Florida
Post Number: 457 Registered: Nov-04
| Posted on Tuesday, April 12, 2005 - 12:26 pm: |
if you want a ported box, and you've never built one, you may want to let him build it. if you want a sealed box, build it yourself. they're pretty easy. |
