Home > Message Board > Car Audio > Amplifiers > Archive through April 15, 2005 > Mtx problem
Author Thread: Mtx problem
my mtx amp isnt getting any power so i checked my remote and battery cables but nothing worked. anyone got any suggestions?
Username: Subfanatic
Walton, Ky
Post Number: 2003
check the pos and ground on the amp
Username: Mad_at_madd
Chico, CA
The majority of the time, when there is nothing wrong with the amp itself, the problem is a bad ground. Try moving your ground to a different spot. Make sure the spot is sanded down to bare metal and that the ground wire is no longer than 3 feet long.
Username: Velk4425
Post Number: 13
Check these
1) Fuses (amp + battery)
2) Ground Cable
Home > Message Board > Car Audio > Amplifiers > Archive through April 15, 2005 > Mtx problem [ « Previous ] [ Next » ]
