Thread: 1200 watts rms and a 15 inch Ti |
Gold Member Username: Subfanatic
Walton,
Ky
Post Number: 1991 Registered: Dec-04
| Posted on Tuesday, April 12, 2005 - 01:00 am: |
guys, im going to run a JBL 1200.1 at 2 ohms to my 15 inch TI, and i want to run all 1200 watts rms to it, what kind of box can i put it in to safely do it |
Silver Member Username: Tragedy
San Jose,
CA
Post Number: 205 Registered: Feb-05
| Posted on Tuesday, April 12, 2005 - 01:09 am: |
werent you selling that 15"? what about the mt and all the amps you were going to run =).. |
Walton,
Ky
Post Number: 1993 Registered: Dec-04
| Posted on Tuesday, April 12, 2005 - 01:11 am: |
i wanted to, but im afraid of hurting my cars electrical system
Silver Member Username: Jwbulger79
Florida
Post Number: 451 Registered: Nov-04
| Posted on Tuesday, April 12, 2005 - 01:12 am: |
a sealed box will allow you to put the most power to the sub. |
Unregistered guest |
| Posted on Tuesday, April 12, 2005 - 04:57 am: |
I agree with J.W., a sealed box is the most stable type of box. However, a vented or ported box would get you about a 3dB gain, but a the same time it will reduce the life of the speaker. |
Florida
Post Number: 458 Registered: Nov-04
| Posted on Tuesday, April 12, 2005 - 12:36 pm: |
i was actually refering to the power handling of the sub, not the stability of the box. a ported box, b/c of its ability to release pressure through the port, will allow the sub to reach full excursion with less power. in the same respect, it will also allow you to overpower the sub easier. i believe the TI is a 750 watt sub; 1200 watts is a lot of power for it, but if you are careful with your gain settings, you should be ok. |
Walton,
Ky
Post Number: 2004 Registered: Dec-04
| Posted on Tuesday, April 12, 2005 - 02:17 pm: |
ok cool, yea i can pick upp a nice jbl 1200 for a good price so i want to kepe this amp if i ever add sh*t to my system and it will run the TI decentlyo only getting close to doubling its power lol |
