Thread: Memphis Belle amp question |
New member Username: Onthelow
Post Number: 1 Registered: 02-2004
| Posted on Wednesday, February 25, 2004 - 06:13 pm: |
hello everyone. im thinking of buying the memphis belle to match up with the 13w7. i want the belle because its capable of powering the 13w7 at 1100w rms and push the my components at 75w /4. it should make for a real clean install. or should i stay with the JL 300/4 and buy the JL1000/1. just looking for some opinions before i make this purchase. thanks |
Post Number: 2 Registered: 02-2004
| Posted on Wednesday, February 25, 2004 - 06:29 pm: |
anyone? |
Post Number: 1384 Registered: 12-2003
| Posted on Wednesday, February 25, 2004 - 06:37 pm: |
Memphis makes very good amplifiers. It'd probably be a cheaper solution to the JL amps, though the JL amps might be slightly better. Either way you'd have a good system. I like Memphis' higher end stuff.
Post Number: 3 Registered: 02-2004
| Posted on Wednesday, February 25, 2004 - 06:56 pm: |
thanks GlassWolf, the main reason why I want the the memphis is primarily the install and trunk space & it looks good lol. it packs everything in one 5 channel amp. the cost here would be about the same. thanks again, I believe i'll go with the M Belle... |
