Home > Message Board > Car Audio > Amplifiers > Archive through April 11, 2005 > HU and Amp power...quick question
Author Thread: HU and Amp power...quick question
Username: Goon
Post Number: 86
I am uncertain of something. my HU pushes 25w rms 50w max...if i were to hook up an amp that does 50wrms a channel, would it add to my HU power...making it 75wrms? Or would the amp over-ride the HU and push it's 50wrms independently? thanks for the help guys.
goon
Username: Carguy
Post Number: 2298
Your HU and external amp are 2 separate product. You can either use the HU's amp or the power amp.
The answer is no, it will not add, 25w or 50w.
Almost any amp is better than the one on HU.
Username: Goon
Post Number: 87
Yeah I knew that...i just didn't want to buy an amp and expect the extra wattage from the HU to be added...glad i got it straightend out. thanks isaac.
goon
Home > Message Board > Car Audio > Amplifiers > Archive through April 11, 2005 > HU and Amp power...quick question [ « Previous ] [ Next » ]
