Home > Message Board > Car Audio > Amplifiers > Archive through April 11, 2005 > Amp fans....
Author Thread: Amp fans....
Username: Volsrule2069
Post Number: 32
can you mount a fan onto an amp that doesnt ahve one? if so how?
Username: Carguy
Post Number: 2294
If the amp has heatsinks that's visible from the outside, then mount it there. If it's one of those that's hidden inside, then you can cut a hole for the cpu fan air circulation.
The power can be shared with some power LED or display light. All you need is something that supplies 5v.
Home > Message Board > Car Audio > Amplifiers > Archive through April 11, 2005 > Amp fans.... [ « Previous ] [ Next » ]
