Home > Message Board > Car Audio > Amplifiers > Archive through April 11, 2005 > How to Wire in 1 ohm
Author Thread: How to Wire in 1 ohm
Username: Smokeysmoke420
I have A fuison 15" with a 1600w max but a 900w rms i would like to knoe how to get the 4 ohm dvc's to go down to a 1ohm mono load.
I have a 2400w power acoustik mono series amp and i want more thump
Username: Chungy
Australia
hi Lance,
Check out this site: http://www.lalena.com/audio/faq/wiring/
Under the heading: "What is a dual voice coil (DVC) speaker?" you should be able to see 4 diagrams, the top right would be an example on how to hook up 2 DVC 4ohms subs to produce 1 ohm. I know you only have 1 sub so looks like you need to invest in another. Hope that helps
later mate
Home > Message Board > Car Audio > Amplifiers > Archive through April 11, 2005 > How to Wire in 1 ohm [ « Previous ] [ Next » ]
