Home > Message Board > Car Audio > Amplifiers > Archive through April 11, 2005 > Jbl 1200.1 vs. jl audio 1000/1
Author Thread: Jbl 1200.1 vs. jl audio 1000/1
dan1980
how do these two amps compare to each other. which one would be more efficient (draw less current). which one would be better for sq and have more quality...???
Username: Bnd_rulez
Phoenix, AZ
Post Number: 263
The only real significant difference is the price. The JBL is a fraction of the cost and has just about as good build quality. It depends on what you are powering, that would give it more SQ. I would take the JBL.
dan1981
anybody else
Username: Subfanatic
Walton, Ky
Post Number: 1974
The jl will make a sub sound a tad better and wiill KILLL your wallet, go with the 1200.1, great amp
Username: Suleman36
Post Number: 551
which one whould be more efficent and draw less current?
Username: Southernrebel
Monroe, Louisiana
Post Number: 551
Current draw should be about the same on both amps. like sub said, the JL will prolly sound a lil better...but you could get 2 maybe 3 bp1200.1's for the price of 1 JL 1000/1.
Dont under over look the bp1200.1...its a great lil amp.
Username: Suleman36
Post Number: 552
you guys know what the fuse total is on this amp?
Monroe, Louisiana
Post Number: 555
The bp1200.1 will draw roughly 115A when it is wide open. It is fused at 120A. I do 145db with this amp on an SX15.
Username: Suleman36
Post Number: 554
You must have HO alternator in your car right? I whould run it to my avalanche but i already have the jl 500/1 to use. I may just end up gettin it later on when i upgrade to a HO alternator cause i like the price on this jbl amp.
Username: James1115
Wilton, Ct
Post Number: 2263
Hey MO if I were you I would sell that 500/1 and buy a HCCA 250G4 and run the Avalanche at 1ohm thats what I am gonna do as soon as I get a minute to take out my A600 and hook up the 250G4, I cant stand looking at this thing in my room it is killing me. Hey Isaac do you think I should run my A/D/S's with my a600 and have no rears or should I run them with my pcx 480 and run my rear boston acoustics with it? I cant wait to get this done I just cant really make up my mind what I want to do, I am getting the Components installed on the 19th so I have to know what amp I want to run to them by then.
Username: Suleman36
Post Number: 555
What are the numbers on the HCCA 250G4 and whats the fuse rating?? thanks
Username: James1115
Wilton, Ct
Post Number: 2264
80 amps, and 800x1 @ 1ohm at 12volts:-)
Username: Suleman36
Post Number: 557
Theres only one 250g4 on ebay and its refurbished but they are an authorized with a 90 day warranty.?? Cost $299.99 plus 28.00 shipping.
Walton, Ky
Post Number: 1981
so what are the specs on the jbl 1200
Username: Suleman36
Post Number: 558
Does this amp draw alot of current..is it efficiant?
Monroe, Louisiana
Post Number: 557
yea MO,
i have a 180A alt and a 2farad cap.
an HCCA250g4 on that Avalanche would be really nice. I think it is fused at 60A.
Here is what it is rated at:
2 x 50 @ 4 Ohm
2 x 100 @ 2 Ohm
2 x 200 @ 1 Ohm
2 x 400 @ .5 Ohm
1 x 200 @ 4 Ohm
1 x 400 @ 2 Ohm
1 x 800 @ 1 Ohm
these amps are underrated though.
Monroe, Louisiana
Post Number: 559
The jbl is rated at 600w @ 4ohm, 1200w @ 2 and 1ohm. Fused at 120A.
Username: Suleman36
Post Number: 559
wow that is flexible. Nice amp. I could always use my ppi pcx2200 later on when i upgrade to HO alternator which is a nice amp for my avalanche also and that amp is 80A and it reads like this for ratings:
200 x 2 @ 4ohms
400 x 2 @ 2ohms
800 x 1 @ 4ohms
I could use this for my avalanche 15 but how do i wanna wire this to get the right voicecoil and wattage from the amp.
Username: James1115
Wilton, Ct
Post Number: 2269
MO you can use that amp. Wire it in series for a 4ohm load. I would go with that over the 500/1. The fuse rating on the 250hcca is 80 amps not 60amps. I would run either one of those two amps but since you already have the PPI run that:-)
Monroe, Louisiana
Post Number: 560
^^^yea, the 250g4 is fused at 80A...my bad
and like james said...run the PPI
Home > Message Board > Car Audio > Amplifiers > Archive through April 11, 2005 > Jbl 1200.1 vs. jl audio 1000/1 [ « Previous ] [ Next » ]
