Home > Message Board > Car Audio > Head Units > Archive through April 13, 2005 > How do i remove my cd player from car??
Author Thread: How do i remove my cd player from car??
Greggs
i have a pioneer cd player... and a 2000 taurus... i had it installed but i need to recheck the RCA wires in the back.. how do i get it open to check it .... ?? does it just pop in and out easily??
Username: Illuminator
Post Number: 56
The first thing you need to do is take off the trim ring around the unit. Next, you might want to try pushing each of the metal tabs in toward the unit while pulling it out of the metal sleeve it is sitting in.
You might need a flat head screwdriver to help pry it out.
Home > Message Board > Car Audio > Head Units > Archive through April 13, 2005 > How do i remove my cd player from car?? [ « Previous ] [ Next » ]
