Thread: Overheating Vent Problems |
New member Username: Edown
Post Number: 1 Registered: Apr-05
| Posted on Sunday, April 10, 2005 - 12:14 am: |
My KX550.2 amp keeps overheating! I have it hooked up to a Kicker L7 15 and it's running off of a Pioneer DEH-P6700 (I believe) deck. I think I have the gain up too much or something. Any suggestions? |
Silver Member Username: Fishy
Tamarac Ft.Laud,
FL
Post Number: 882 Registered: Sep-04
| Posted on Sunday, April 10, 2005 - 12:39 am: |
First make sure you have that 15 wired to present a 4 ohm load bridged. I hope you have the 2 ohm DVC model with the voice coils wired in series. If not thats your problem. Otherwise turn the gains down.
-Fishy |
Silver Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 263 Registered: Feb-05
| Posted on Sunday, April 10, 2005 - 06:18 pm: |
what Fishy said, or if you have the amp where it can't get good air flow, summer can cause problems to amps under seats and such |
Bronze Member Username: Mixneffect
Orangevale,
Ca.
Post Number: 20 Registered: Apr-05
| Posted on Sunday, April 10, 2005 - 06:26 pm: |
Check your power wire guage. |
Post Number: 2 Registered: Apr-05
| Posted on Monday, April 11, 2005 - 12:45 pm: |
I have a 4 gauge wire, but how do I know if it's bridged, or if I have the 2 ohm DVC model? Also, does my amp have enough power to push the 15 or is it lacking? Would that make it overheat? |
Post Number: 4 Registered: Apr-05
| Posted on Tuesday, April 12, 2005 - 07:02 pm: |
Also, what can I do to make my Kicker KX550.2 amp push the 15 inch L7 the best? What kind of wiring? |
